Fluid change for WD45
sploke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sploke Quote  Post ReplyReply Direct Link To This Post Topic: Fluid change for WD45
    Posted: 27 Jul 2015 at 6:48pm
I just picked up a WD45 and before I start putting it to work, I want to do a full fluid change and wanted to confirm what I'm looking at. I have a manual, so I think I'm looking at 6qts of SAE20 for the crankcase, 17qts of 80w-90 for the transmission, and 1-2qts each of SAE140 for the final drives? Sound about right?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 6:54pm
I've got 10-30 in the engine and universal hy-trans in everything else.  Still have gear oil in the finals, but the rest is hy-trans oil.  Double check your book.  The hyd pump takes 6 qt or so as well.
AaronSEIA
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 7:08pm
SAE30 in the motor, hy/trans in the hydros, and 80/90 in the hand clutch, trans, and finals. That's what I use.
Edited by Josh Day - 27 Jul 2015 at 7:09pm
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2015 at 7:49pm
AaronSEIA
Same here, been that way for 30+ years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sploke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2015 at 7:22am
Awesome thanks.  I was having trouble finding a place that sold SAE140 anyway...this will make things a lot easier.
