floating feeder beater swap?
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Topic: floating feeder beater swap?
    Posted: 10 Oct 2016 at 9:35am
I have an early l2 rice combine with spike tooth cylinder and floating beater. The beater decided to break the drive eccentric (for lack of a better word) and made itself a pretzel from there. I have a parts combine with a corn/soybean beater. Can I swap the two? The rice beater is 3/8 inch narrower and 1" less diameter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 9:37am
It looks like I would have to trim the edges of the corn beater, but it looks like it would work otherwise. I didn't know if a rigid beater would interfere with a spike cylinder somehow or not. Thanks for you help in advance
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 9:05pm
If I remember correctly, you can go from floater to solid but not from solid to floater.     MACK
