Filler Bar ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Filler Bar ??
    Posted: 26 Nov 2019 at 8:22pm
There is a topic on a different forum about harvesting H/M corn with a conventional Gleaner(M2). Some are saying the fillers go on/over the concaves,but I thought the "fillers" went between the cylinder bars? Can someone clarify? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:33pm
you are correct.....they lay on the leading? edge of the bar and clamp against it....been too long but would know if I went to put them in. Used them in some hard threshing corn years ago. They have holes that circle the bar bolt heads to help keep in place. Does the book show them installed?
Edited by SteveM C/IL - 26 Nov 2019 at 8:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:39pm
Thanks Steve, but if your referring to our O/M, it's at the farm. I thought perhaps an F and M/L series had different "fillers".
There is something in the Parts Book called a "lap bar" ?
Edited by FREEDGUY - 26 Nov 2019 at 8:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:41pm
don't know why they would be different. Everything else is same cept for open concave. Rasp bars are  same only different lengths.
The fillers are supposed to give more area to roll cobs on  to help rub kernals off cob.
Edited by SteveM C/IL - 26 Nov 2019 at 8:43pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:45pm
There was some filler plates for M&L that went on concaves, but they were for clover and real small grain.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:46pm
That would make sense,trying to thresh against open concave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2019 at 8:49pm
Maybe I should have tried my filler bars instead of adding 3rd concave? Forgot all about them. Cracked a lot of corn this fall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 7:22am
Filler bars in corn is still thee best way to harvest. Cylinder can be run slower and everything gets shelled off, because nothing slips between the cylinder bars. No one wants to take the time to do it and then there's the back and forth between soybeans and corn...……….
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 4:50pm
After installing the  after market wide-spaced bars(Kuchner?) on our F2, There is really no room to install filler bars Confused.I had a very hard time getting the last cylinder bar fastenedThumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2019 at 10:15pm
Think I'l try that next year....now I got to find them.
