F3 unload auger
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: F3 unload auger
    Posted: 23 Jun 2015 at 8:00am
I am trying to find the unload auger height at the spout for a F3. Any help appreciated.
Part time farming with a 1980 7060 and 1984 F3 hydro.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 9:07am
Depends on tires.
18.4-26s puts the base of tube spout, at 10'.
23.1-26s puts it at 10'-4".
When you mention auger spout, there is the extended tip or the tube base where it connects to tube. The tip drops the height about a foot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 10:46am
Great info-thank you.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 12:34pm
What are you wanting to dump into?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 2:56pm
I want to be able to use the wagons I have as they are but it will be close. They could be modified a little but not much because I want to keep the roll tarps on them.
I don't have the combine yet, just thinking out loud, I guess.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 4:41pm
With a simple attachment to your unloading auger swing out hydraulic cylinder, you can easily add 12 to 16 inches in additional height.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 10:41pm
Well, what are your wagons?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2015 at 11:41pm
When unloading into taller wagons, you get good at positioning machine so unloading auger swings out correctly to just clear wagon edge. If your auger doesn't have a rub rail on its underside, get one put on it ASAP. It almost eliminates auger tubing dings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2015 at 6:14am
Good advice on the rub rail.
The worst thing I did several years ago was forget the auger was out on the K2. I carried it back to to the shed on the corn head.
Jordan-the wagons are DMI center dump with about 8" extensions plus the roll tarp. It is just over 9' to the top the extension.
I need to investigate the extension Dr. mentioned if I decide to get the F3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2015 at 7:31am
Will be tight, but doable.
What the Dr. mentioned is not an extension, it's adding a stop to the cylinder so it doesn't swing out all the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2015 at 7:45am
I figured I would just dump on both sides. This will keep me from topping them off where they get a little top heavy. I have two and they will hold about 750 bu. together which is enough for the 7060 to take down the road.
Now just to get the combine.
Thank you all.
