F 292 running hot
Dmpaul89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dmpaul89 Quote  Post ReplyReply Direct Link To This Post Topic: F 292 running hot
    Posted: 23 Sep 2016 at 7:02am
its pretty warm harvest conditions. when it gets to 90 outside the needle gets to red and when i shut off the engine it will diesel until i put the choke on. radiator fins look clear.       should i richen the fuel mixture needle? or is it most likley clogged inside radiator.    it doesnt boil over the pressure cap will open sometimes though
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 7:07am
I don't have any tips to fix the problem, but when they get hot like that, you shouldn't just shut them down except as a last resort. Better to let them idle and cool down, UNLESS they just keep getting hotter. When the engine is that hot and expanded, it's hard on it to cool down and contract that fast.
Did you try blowing out the fins with an air nozzle and see what comes out?
Edited by Allis dave - 23 Sep 2016 at 7:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 8:21am
I had the same problem with my F gleaner.  Turned out the timing was way off.  It is very difficult to see the timing marks the way the engine is positioned on the combine.  Try setting the timing correctly, then make two visible marks on the pulley and timing cover where it can be seen easily, so you can check it periodically.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 4:35pm
We used to have a Gleaner F with the Chevy 292 gas engine.  4 row corn head and 13 foot table.  It always ran hot.  The dealer claimed it was just the way they were.  Suggested we keep the fan belt "fiddle string tight".  Not enough radiator capacity.  Always a good idea to keep the radiator clean and check the rotary screen for plugging.  Once I had an oil leak in the hydraulic hose near the radiator's rotary screen while combining soybeans.  Talk about running hot then!!!  Had to take the screen off, go back to the house, and wash the screen with soap and water.  Put the screen back on and it plugged up with soybean dust again.  Took it to the shed and cleaned it with gasoline.  Scrubbed it good.  That finally cured it.  We never had any engine problems with it, though.  Just always ran hot.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 8:10pm
it's out of time if it's running hot' needs to be advanced a little bit' will sure work better' an run cooler''
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 10:11am
LOSE the muffler!  It is too small for that engine - it holds a lot of heat.  If you look on the inside of your bin, you will probably find a scorch mark that area.  My dad removed the muffler on his F years ago.  Got a piece of pipe bent to the shape of the muffler and ran it for years.  It was much cooler and was not any noisier!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 3:53pm
also check the inside of your rotary screen for build up of dirt on the blades. that will slow the screen from turning and as you are running dirt may be building up on the outside blocking some/most of incoming air. also check the bearing. this happened on a neighbors combine once.
