Ever see one this bad ? Bent Push Rod
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Ever see one this bad ? Bent Push Rod
    Posted: 22 Nov 2016 at 7:57pm
Tractor was running fine, parked it and tried to start it a few days later. It would not start. Pulled it off to get it started and it ran very bad.
Pulled spark plug wires off one at a time as it was running "BADLEY". #1 made it run a little worse. #2 and #3 made it run much worse. #4 was dead, it had no effect. Compression test showed #1,2 and 3 at 130 PSI and # 4 at 110 PSI. [/IMG]
Edited by Macon Rounds - 22 Nov 2016 at 7:58pm
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:07pm
YES! I'm going through the same exact thing with the 170. Intake valves on both cylinders affected were not moving freely in the guides. I just had the head redone before this. #1 and #4 had the bent pushrods. Hope someone here has an answer.
There was a sticky residue on the valve stem and in valve guide if that means anything
Edited by plummerscarin - 22 Nov 2016 at 9:06pm
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 8:24pm
Yes,  I bought a D10 a few years ago that had a skip.  I thought it was a spark plug or wires, but finally pulled the valve cover and found a push rod bent like yours.  I replaced the push rod and the tractor ran fine.  Since I could not find the cause of the bending, I think it is possible that after years of use the push rod just weakened and bent for doing its job.  (only a guess)  If you need a used push rod, I have some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 9:15pm
Well,,,, I have a theory.
I had recently put some old questionable gas in the tractor. Then wife used it to putt around the ranch for a "few hours" picking up small branches and debris. She ran it at low idle most of the time and said it was running fine when she parked it.
So, I believe the intake valve stems coked up with carbon and gas varnish which made the valve stick in the guide.
What are your thoughts ?
Pertinent INFO : This tractor has about 750 original hours, so it is nicely broke in. I had just changed the oil a few hours prior to the event and checked the timing. Ambient temperature was in the 80's. And ironically when I changed the oil turned up the fuel a 1/2 turn richer. Most likely making matters worse.
Edited by Macon Rounds - 22 Nov 2016 at 9:49pm
dgerth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dgerth Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 9:24pm
I will probably get booed here, but I had a IH 706 dsl that had bent push rods that were unavailable at the time, I used a block of wood and straightened them and installed and they ran fine till I sold the unit 4 yrs later. I have since done this procedure a couple of times with good success  but only with solid rods. Just my $ worth of experience.
dg
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 10:07pm
"Ambient temperature in the 80's" don't have to rub it in!
Life is tough,but it's tougher when you're stupid. - John Wayne
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 10:25pm
Varnished up gas caused your problem. Didnt set up while the engine was initially running but after cooling down it got real gooey and stuck the intake valves. Probably gonna have to drain the tank and in my experience clean the tank. Varnish substance will be on the walls of the tank and continue to cause problems.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2016 at 11:11pm
yep....when I question.....blame the loving wife!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:46am
Bad Gas !!! Could be problematic at Thanksgiving.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 8:55am
Heck Ben, just load it up and bring along on your next trip this way!
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 10:53am
 I had one that got in the crankcase of our lawnmower and when it came out it looked like someone try to tie it in a knot. Looked just like a pretzel.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 12:07pm
Hey Joe !!!!! Just why would you want a bent pushrod ? Or were you wanting me to bring the whole tractor your way .... Ha ha !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2016 at 5:21pm
Allisman, at first I thought no.. I put fresh gas in it. but your residue theory has merit. I'll clean that tank good while it's down, thanks.
