Engine vibration
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Topic: Engine vibration
    Posted: Yesterday at 9:17pm
I have had this tractor over 20 years and this year it seems to have excessive engine vibration, sometimes, when the throttle is halfway or more. I noticed it a couple of weeks ago. After that it seemed normal, then today ( bush hogging a small field) it seemed excessive.  This is without running the pto or anything.  I don’t know, maybe I am going crazy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:40pm
What model and gas or diesel ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 18 minutes ago at 8:33am
Gas.  I know 4 cylinders vibrate anyway, but this seems excessive, I should remove the plate under the flywheel and clutch and have a look.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 16 minutes ago at 8:35am
WD 45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 55 minutes ago at 8:56am
Tighten up the bolts that hold the engine to the bellhousing (4). Tighten up the bolts that hold the engine across the frame at the front (4).
