engine problem |
Post Reply |
Ed&Sherry
Silver Level Joined: 08 May 2010 Location: Owego, NY Points: 234 |
Posted: 13 May 2018 at 9:38am |
wrong color ,,,JD8400,,plowing ,engine bangs and stoped,,,,last night pulled the valve cover and found one broken rocker arm, one bent push rod,,but the rockers are all real loose to the point you can remove all of the rods by hand,,the rocker arm ass. is tight and not broke....what happened??? broke cam gear?could the cam slide forward? thanks
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50532 |
I know they can slide, if the cam is busted...
Orange Level Access Joined: 12 Sep 2009 Points: 19523 |
If the engine is locked up? ... you'll figure it out when you tear it apart.
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3199 |
You may want to check the 8400's transmission for a fault which it's 8.1L engine may have absorbed the transmission's stopping forces??
https://www.redpowermagazine.com/forums/topic/7759-a-john-deere-that-ate-itself-for-lunch/?page=2 |
MACK
I would say cam shaft is broke for some reason. Most common reason is when it throws a rod, it usually gets the cam. MACK
Ed&Sherry
broke cam,1 lobe off crank,,1 sleeve bottom broke , crack in block other wise good to go
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22810 |
My neighbor bought a slightly used JD8110 a few years back. Didn't get 200 hours out of it and the engine puked. Scoured piston on one cylinder. He did a little internet checking, and found it was a common problem on that engine, but JD never fessed up to the problem.
They told him some ridicules price to put one piston and sleeve in, but couldn't guarantee the others would hold up. I think it was 14K to get it back in working order with new sleeves and pistons. I have run it a lot, and it's pretty handy for light tillage work, but lacks higher field speeds , just can't figure why JD would let that engine go with known problems in them. Edited by CTuckerNWIL - 20 May 2018 at 8:40pm |
Brian Jasper co. Ia
Orange Level Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Post Reply | |
