Engine options for a B
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Topic: Engine options for a B
    Posted: 22 May 2012 at 4:33pm
Probably been answered before, but what engines will bolt in to a B, besides a BE and CE engine?
Such as D14 149", D10-12 138", D10-12 149'', D15 149", D15 160", ??
My winter project low B with a 6' mower needs an engine, be nice to find a 138 CI, or 149 CI engine for it. I don't want to put $ in the current engine (in poor condition) as it's a BE 116 CI, and not quite the power needed anyway.
Thanks Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 6:38pm
I've seen a B with a D-14 engine on Kijiji up here( I'll try to snag a picture)...
..something else to do,wish it'd rain........sigh.....
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:15pm
The 149 will likely be the most bang for your buck, but all that you mentioned will work with little effort.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 10:35pm
I have a running CE engine I would sell if you have interest.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 6:24am
I believe the 149 D14 engine is a bolt in. Not sure on what's needed for clutch/flywheel combo if needed, but that would make that little B rock n' roll. You'll mow some grass wit dat little bugger then Bill dat's fir sure!  Thumbs Up
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 9:57am
If you are looking for power this B has a 201 from a WC.
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 1:27pm
Ithought all 116  in  engines had mags. instead of distrubators.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 6:58pm
The series III D-10 has the 149 engine in it.
Dusty
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2012 at 10:10pm
A 138/149 engine will bolt up to a B, but you must use the flywheel, pressure plate, and clutch (8 1/2") from the B fo it to work. You will have more power from a 149 then from a 201. You might find that you will have more power then your B will know what to do with. A D14 is about double the weight of a B. You might also reduce you tranny and rear end gears to a pile of metal. The 116 engine came from the factory with a mag, but 70+ years later it could be wearing most any other option. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 1:20am
With everything Bob said it may be wiser to go with a 201 in instead of the more powerfull 149. You should be able to find a 201 more readily given it's production numbers and the lower compression ratio of the 201 makes it easier on starters.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 11:18am
How many horses does the 149 put out?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 11:29am
I would be surprised if a fresh 125 wouldn't handle that mower. Most that I've been around will make 25-30 HP, and way more low end torque than a Kohler/Kawasaki powered zero turn mower. A 201 would require an adapter plate at both ends and significant work in the flywheel and clutch department.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 11:40am
The 149 dressed in D14 clothes made about 36 HP at the PTO. Later versions like the D15 series I made more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 12:09pm
We pulled an all crop 60 with a wc  with pto , traded wc for D/14 and it had more  power .My old sales books  says a B 2020 lbs  -- D/14 4200lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2012 at 9:31pm
A 149 will bolt right in, a 201 will require a lot on modifications. Bob
This page was generated in 0.111 seconds.
