Engine Oil for 2035 |
psheridan
Joined: 10 Apr 2016 Location: Omaha, Nebraska Points: 107 |
Topic: Engine Oil for 2035Posted: 14 Jun 2017 at 9:35pm |
What viscosity of oil should I use in my 2035
straight 40wt? 30 Wt? Also , I suppose that since the pan has two petcocks, I would fill the pan up to the lowest petcock?. if so , what is the highest petcock for? I dont have a spec on the oil capacity, I do not have a owners manual yet. Also, I would suppose that the governer takes the same oil and to the petcock as well? thanks for the help Paul
Auntwayne
Joined: 23 Apr 2011 Location: Edwardsville Il Points: 1589 |
Posted: 14 Jun 2017 at 9:57pm |
Manuals available by vendors on this site.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
DanD
Posted: 15 Jun 2017 at 9:29am |
Either of those oils would probably be fine. Would be way better than what was available when the tractor was new. If the engine is not in new shape, 40 would probably be great. I assume you won't be starting it on a -20 morning! As far as the two petcocks, I've seen instructions that when running on low octane fuel, you are supposed to drain the oil down to the lower petcock and refill to the upper at some interval that's more frequent than for a full oil change due to oil dilution from the unburned fuel that makes it into the crankcase. Like the other post said though, get a manual and read it. Will always be something you didn't know or even think about.
Edited by DanD - 15 Jun 2017 at 9:30am |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3959 |
Posted: 15 Jun 2017 at 11:17am |
from the operators manual:
Pan should be filled to upper petcock and oil level maintained between the upper and lower petcock. They serve a similar function to the upper and lower level marks on a dipstick. Governor should be filled to the petcock with same oil as used in the engine. Edited by Alberta Phil - 15 Jun 2017 at 11:17am |
psheridan
Posted: 15 Jun 2017 at 6:32pm |
Thank you very much for your replies
the nice thing about his website is that you most often get real experienced replies and often times opinions and comments that you do not get from the manual. this is more than just a manual site ! that is why I keep coming back for more thanks Paul
