Early D14 Steering shaft/wheel |
rasman57 ![]() Silver Level ![]() ![]() Joined: 12 Sep 2009 Location: Illinois Points: 411 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Mar 2022 at 10:24am |
Working on my 1958 D14 with the steering wheel that uses a pin through the shaft. In spite of it being incorrect for the year, I would like to put one of the newer model steering wheels with the center diamond for the power steering emblem....maybe even in the later year white. Splined shaft I think.... Anyone swapped out parts to do this?
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24571 |
hmm wonder if it'd be 'easy' to just swap steering wheel AND upper shaft ??
That's what I am wondering.....if the upper shaft to the swivel could "match up" or if the design change was deeper for the later models that used the newer wheel.
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Yes make sure u get #4 ,5,6 when u pull shafte from later tractor . Here is a parts unit I have .Just never got that far where I can pull the shaft.
![]() Edited by Fred in Pa - 13 Mar 2022 at 1:29pm |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
I am patiently working on the pins for both the steering wheel and the upper shaft. I read here the pins are tapered and/or swaged on the ends, so I am trying soaking and tapping (banging with drift) to see if I can get any directional movement. Taper does not make sense but perhaps. The early parts diagram show pins with no description or numbers and look sorta like split roll pins but I am betting they are solid AND rusted SOLID too. Thanks Fred, that one looks like it is gonna stay forever...wow!
Edited by rasman57 - 13 Mar 2022 at 1:57pm |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5044 |
I believe that I have the steering shaft that was removed from a D14.
I was able to drill the pin holding the upper steering shaft to the first U joint below the shaft and it separated with a few taps and some juice. The steering wheel pin is a different story after rusting in place for 64 years so I am happy to be able to lift the wheel and shaft out together.
The shaft measures .875 (7/8ths) and the pin hole is approximately 3/8th of an inch.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7482 |
Black steering wheels are available for later model D14s with the power steering emblem. Please don't put a cream steering wheel on a D14!
Good to know..... It isn't a NAFTA violation I hope. I just sorta like the steering wheel. I promise I won't drive it to Ontario.
