Early B serial numbers |
Post Reply |
wdfifteen
Bronze Level Joined: 20 Mar 2012 Location: Ohio Points: 4 |
Posted: 20 Mar 2012 at 10:41am |
Does anyone know where the serial number is located on early (Waukesha engine) Allis-Chalmers Bs? I looked at one the other day and could not find a serial number in the usual location. In fact I crawled all over it and couldn't find any number that looked like a serial number. Does anyone here have one of these tractors?
GlenninPA
Orange Level Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Brass plate, not by the transmission shifter, I think on the final drive, but my memory is failing me.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Nathan
Silver Level Joined: 14 Sep 2009 Location: ohio Points: 370 |
You just tell me where that tractor is at in ohio and i will be glad to tell what serial number it is. thanks nathan |
35WC 37WC D-10 D-12 D-14 D-15 D-17series 1 (2)D-17IV D-19 CA RC Unstyled WF GLEANER E 416H 314H 712H 716H
MNLonnie
Orange Level Joined: 11 Sep 2009 Location: Baxter MN Points: 4790 |
I think it's on the torque tube.
Waukesha B, B, IB, G, styled WF, D15, 615 backhoe, 2-Oliver OC3's, 6 Ford Model T's, 3 Model A Fords, AV8 Coupe, AV8 Roadster, 1933 Ford Wrecker
Rfdeere
Orange Level Joined: 11 Sep 2009 Location: Idaville, IN Points: 3282 |
Jamie's post here shows the serial # plate: http://www.allischalmers.com/forum/forum_posts.asp?TID=29415&KW=waukesha&title=waukesha-b-serial86-is-here |
http://www.rumelyallis.com |
MNLonnie
Right where the battery would sit on a newer one. If there is no plate there should be rivet holes where it was or it's not a Waukesha. What are signs that lead you to believe it's not an ordinary B?
wdfifteen
So, the plate is missing on this one.
It's definitely not an ordinary B. It has a Waukesha engine for one thing. The castings for the torque tube, transmission, and final drives are more crude than on a later B. The flanges where the final drives bolt to the transmission are thinner (and cracked around the bolt holes). There is no pad cast into the top of the transmission for the serial number. The shifter is held in place by a plate bolted to the top of the transmission. There are no gear position numbers cast into the transmission - those are the only differences I can think of off the top of my head.
wdfifteen
Thanks to everybody who replied!!
Post Reply | |
