E combine engine swap update
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: E combine engine swap update
    Posted: 03 Aug 2012 at 9:44pm
The governor and housing seem to be differant. There are several differant part numbers.  Springs,thrust bearings, and governor shafts are differant. Looks more involved than first thought. Any help appreciated on swap. Thanks Tracy Martin
Edited by Tracy Martin TN - 03 Aug 2012 at 9:45pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 10:18pm
There was a Gleaner E combine governor on a WD45 engine I bought for my WD project... the governor is totally different from that which came off of my WD.  I suspect that the governor is different, because the operational uses of the combine, being a specific-function machine, has different throttle management requirements than a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 6:55am
I guess I don't understand what the problem is here. All governor parts between a 170/175  gas engine will interchange with an "E" Gleaner engine. The engine block is essentially the same as is the timing cover. Transfer over all tractor engine parts to the combine engine and be sure to adjust gear backlash. Use tractor throttle lever and bushing etc and install into timing cover or just swap timing covers.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 7:48am
        Dr. Allis is right on. Replaced Motor in a D17 and thats exactly what we had to do to the Gleaner Governor. Works perfect.
                                        John Carlson
