Dynoed my WC Video
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:27pm
Stick to texting them. They laugh at you in person and don't want to talk to you anyway. Texting takes the personality out of it and will save your feelings some pain
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:34pm
its obvious you dont know why i would txt tracy . he has a hard time reading lips or seeing signs tthrough the phone. So its obvious you havent pulled against him . so hows setting  in the stands been
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:49pm
Originally posted by mlpankey mlpankey wrote:
we havent been to eagleville in a while .  how did you do . its not hard for me to txt tracy reed or call cody so no need to exagerate acomplishments.
Does this mean that I'm elevated to the same status as wi50? You are also his 'internet stalker'
I don't pull anything there is a class fo Eagle.ville. I run with windmills and smoke
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:59pm
Most stalkers are spectators since your spectating pulls of wi and traveling to tn looming for me i would say you qualify as both of our stalkers.now quit high jacking Aarons posts
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 8:29pm
Originally posted by Rod B Rod B wrote:
Carefull pank. What you may realize (if you learn enough) is that power comes from an efficient engine design. Part of that may be rod angle.
It's going to be a trick assignment for you. But when you do find a piston to measure and come back with some solid info please tell us what the compression height of both an AP46 and AP48 are. As well as the pin offset.
its real easy for a do it yourself mechanic to see that its easier to move air through the overlap induction signal with a short rod moving the piston than it is for a long rod thats dwelling during this time relying  only on  harmonically tuned dynamic flow from exhaust and intake tract to move air since the piston is in dwell during this time . my 2 cents
Edited by mlpankey - 10 Sep 2012 at 8:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 8:54pm
I was standing on the edge of my toilet hanging a clock, the porcelin was wet, I slippped, hit my head on the edge of the sink. And when I came through i had a revelation, a vision, a picture, a picture in my head. A picture of this. This is what makes time travel possible. The Flux-capacitor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 9:00pm
its hard to fill a tollet with the lid down as its hard to fill a cylinder with the piston dwelling at zero deck even if flow is good it just runs off the lid into the floor or in the intake right out the exhaust neither bowl or cylinder gets a thing from the flow but raise the lid or move the piston down and your doing more than pissn on your feet.
Edited by mlpankey - 10 Sep 2012 at 9:03pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 2:12am
The point I'm makeing is so far over pankey's head he fails to even realize it. Pointless to go any further with the subject.
Yep.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 6:28am
I'm looking for a smiley face with a belly laugh.
Edited by Lonn - 11 Sep 2012 at 7:19am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 7:00am
I watched pankey TRY and argue with wi50 about compression on these M&W pistons for 2 weeks one time. Finally pankey called a friend of mine, realized he was wrong and then changed his argument to something else.
It was a simple case of A+B+1/2C=X and X is greater than the deck height of the 226 block.
So pankey did you do your homework yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 8:12am
No one changes topic better than rod. He managex to do it high jacking Aarons thread three times and still stalking.
This page was generated in 0.111 seconds.
