Drilling holes in concrete |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3090 |
Topic: Drilling holes in concretePosted: 18 hours 26 minutes ago at 2:43pm |
Drilled 4 today. Brand new concrete bit. Went well for about an inch. Then it was tough. Does a hammer drill make much difference? I have more to do, Thanks
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42062 |
Posted: 18 hours 13 minutes ago at 2:56pm |
Big Difference with a hammer drill -bigger the unit the better and faster the drill works .
Trawler II
Joined: 04 Jul 2017 Location: Missouri Points: 3544 |
Posted: 17 hours 42 minutes ago at 3:27pm |
A rotary hammer drill and SDS bit will be a night and day difference. If you have a lot of holes to drill renting a rotary hammer drill and purchasing a bit is the way to go. SDS bits are a bit expensive compared to standard carbide, with a lot of holes to drill they are a bargain.
Edited by Trawler II - 17 hours 41 minutes ago at 3:28pm |
"Most people find it easier to believe a simple lie, than the complex truth"
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34548 |
Posted: 16 hours 30 minutes ago at 4:39pm |
If has Creek rock in the mix is like drilling granite.
ACinSC
Posted: 15 hours 7 minutes ago at 6:02pm |
Thanks guys. Good info!
DougG
Posted: 15 hours 1 minutes ago at 6:08pm |
Creek rock and rebar get in the way- take a punch when it stops and try to break the rock- we use Makita battery powered drills and sds bits , they hold up well - and get used hard at work
Edited by DougG - 14 hours 58 minutes ago at 6:11pm |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4971 |
Posted: 13 hours 49 minutes ago at 7:20pm |
What size holes are you drilling? Hammer drill and SDS Bits are the only way to go . Like others have said bigger is better. Rentals can pay for themselves quickly.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
omahagreg
Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2808 |
Posted: 11 hours 49 minutes ago at 9:20pm |
Years ago I had almost 60 holes to drill in 2 commercial bathrooms-tile and cement. I started getting 12 holes drilled but wasted 4 bits-masonry in a hammer drill. I said screw it and went straight to Hilti-bought a new SDS drill and their bits! They have a 2 carbide tip where most others are a one carbide tip. Just used one bit on all the rest!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
ACinSC
Posted: 2 hours 33 minutes ago at 6:36am |
Plan B . Back out this morning for wedge anchors. One tapcon wouldn't hold. Feel sure I messed up the hole putting too much 'fat boy' on the drill
Drilling 1/4" holes. Thanks |
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6513 |
Posted: 2 hours 6 minutes ago at 7:03am |
Not too much fat boy on the drill but when trying to get through a piece of rock with a regular drill will cause the bit to wander. Hammer drill eliminates a lot of the wandering.
Gary (sw Wis.)
Silver Level Access
Joined: 12 Sep 2009 Location: S.W. Wis. Points: 220 |
Posted: 1 hour 22 minutes ago at 7:47am |
Rotary hammer drill is the key. Not a hammer drill. And then let it do the work, don't push to hard you will be surprised.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Joined: 11 Sep 2009 Location: illinois Points: 88755 |
Posted: 1 hour 18 minutes ago at 7:51am |
i have epoxied a few studs into concrete holes... set for 24 hours and then tighten the nuts... had good luck..
ACinSC
Posted: 42 minutes ago at 8:27am |
Plan B didn't work
Guess I need an anchor for a 5/16 hole or maybe Steve's suggestion? Thanks |
