Does Ac 190xt have a hydraulic screen or strainer?
whizone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Topic: Does Ac 190xt have a hydraulic screen or strainer?
    Posted: 25 May 2018 at 8:03pm
Getting ready to work on the old 65' 190xt lift tomorrow and was wondering if anyone can tell me if there is a hydraulic system screen or strainer to check and clean? Thanks All..
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 9:07pm
Yes it's at the bottom of the sump. That plate with the suction hose has a screen above it
Post Options Post Options   Thanks (0) Thanks(0)   Quote whizone Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 9:40pm
so how do you access it to clean it?  will I have to drain all the hydro fluid?  my lifts will not work and was thinking it may be that... thx much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2018 at 8:15pm
If the fluid hasn’t been changed for awhile, it would be wise to change it anyway. Oil is cheap compared to transmission problems. Otherwise place a 5 gallon bucket under it and drain the sump. I think its 8 bolts if I remember correctly. The screen is attached to the sump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 1:36pm
Old 190's like that originally had a round strainer inside the left frame rail. It was about 3 inches in diameter and 6 or 8 inches long. They were a constant source of problems and many have been removed and replaced with a piece of pipe. It might still be there and it might not be. It's 50%/50%.
