Do Farmall A weights fit AC b/C/CA? |
KMAG ![]() Orange Level Access ![]() Joined: 26 May 2020 Location: Elizabethtown, Points: 680 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jul 2022 at 9:13pm |
I found a junk Farmall A with front and rear wheel weights. Do they fit AC rims?
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4085 |
Interesting question. I have a set of said weights, will have a look today.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5105 |
NO: Those rear wheel weights are for Dished wheel centers as the NON PAW wheels that sometimes are on D10/12 tractors, if you has those wheel, they will fit.
Although the complete rear wheel rim/assemblies do interchange onto a CA, The Farmall A/B weight will not fit right on The AC CA PAW wheel centers. Although for the Farmall weight may fit somewhat onto an Allis B or C wheel. Depends on how well you want them to set on the wheel. As for the Farmall front weights they mount in a completely different fashion.
John WV ![]() Silver Level ![]() ![]() Joined: 30 Oct 2010 Location: bunker hill wv Points: 273 |
i don't know if they fit but my farmall super a on the rearend weights are not the same weight transmission side of the tractor is lighter then the other side so that the tractor weights the same both side
