Distributer Conversion, kit Per Trtronix ???
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: Distributer Conversion, kit Per Trtronix ???
    Posted: 23 Sep 2016 at 5:51pm
Anyone know the part number for PerTronix Conversion kit for 4cyl. Ford 2000 tractor ? This tractor has been converted to 12 volt, negative ground. Using alternator.
Ready for ignition upgrade.
Thanks in advance
Edited by Macon Rounds - 23 Sep 2016 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 6:09pm
most places that sell pertronix will have a list of the kit you need.  You will need to know if it is + or - ground, and a 3 ohm resistance coil, I believe.  Cheapest place I have found is the Brillman Co, virginia...
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 6:51pm
Steve at B & B custom circuits can set you right up. Or get the part number off the distributor and search for a kit to match that distributor.   It should be a 12 volt negative ground tractor and you should have a 3 ohm coil without a resistor.   The older ford 800 serries was 12 volt negative ground with a 3 ohm coil so I am pretty sure the 2000 is as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2016 at 7:45pm
Thanks for the replys !!!!!
