Discing with the D 15
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Discing with the D 15
    Posted: 6 hours 19 minutes ago at 5:38am
Some of our roads/firebreaks are so curvy that I use the inside brake to get through. Guess this makes the inside discs 'dig in ' and I wind up with a banked road. Any way to prevent this? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 37 minutes ago at 6:20am
Disc must be level side-to-side. Raise the front gangs up some and let the rear gangs pull the dirt back in. Less severe turns would help if you can. If you use the left brake going one way, I'd think you'd be using the right brake coming back ????
Edited by DrAllis - 5 hours 33 minutes ago at 6:24am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 26 minutes ago at 6:31am
Thanks Dr Allis. I can try lowering the back gangs with the top link. Have to negotiate around trees in quite a few places and I do use the inside brake both ways. Not that big of deal but a level road would be nice
I'll check my lift arms too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 36 minutes ago at 8:21am
Lift the disc!!! 3PT equipment was not designed to go around corners. I know everyone does it, that is why so many of the 3PTs on D10/12/15 tractors are ready to fall out from under the tractor.
  If you MUST turn with lowered ground equipment make up some stabilizer  irons like Ford tractors use. this will take some strain off of the 3PT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 34 minutes ago at 8:23am
Snap coupler hitch is actually better for contours and turning !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 24 minutes ago at 9:33am
Raising the disc would work but I don't want a gap in my firebreaks. My 3 point is an aftermarket Cross? , pretty robust. Doubt the D 15 could hurt it . I do wonder if a snap coupler disc wouldn't work better. Thanks!
Edited by ACinSC - 2 hours 22 minutes ago at 9:35am
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 28 minutes ago at 11:29am
Being on the left coast everything is different, Wink as to growing things as well. So I am shooting in the dark. How often do you till the fire brakes, how much growth? Could you use an angle blade on some of your passes? Pushed the dirt back where it came from.
Here we would run a old style offset disc without wheels. With hydraulic ram, we remove angle of set in the disc. So the only cutting action is from the turn with no angle of set in the disc. Even if you could find one in your area, no idea if the non wheel part would work at all for you. Again just differences in how things get done in different places. Not that ether one is best.
