Disc identification
Daniel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Quote  Post ReplyReply Direct Link To This Post Topic: Disc identification
    Posted: 12 Oct 2012 at 4:50pm
Any ideas on this disc? Its 6ft wide and I can not find any markings on it...I'm not even sure how old it is. Last time it was used was by my dad around 15 years ago.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 4:55pm
international harvester
Life is tough,but it's tougher when you're stupid. - John Wayne
Teddy (punchie) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 7:57pm
Yes IH old I would say 50 years any way maybe more.  I have two; one in the scrap and one setting. I was a very young the last time we used one. Looks to be just the front, most had a back section to.
Ac D-19, a Number of WD's, One WD45, Two 444 balers, Ac plows and etc.
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 8:33pm
I have a 20 disk and a 16 disk. I was told they are 19B International. Kaleb and I used them today and they sure do a good job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2012 at 11:15pm
Thank you! You guys are so great!
I'm wanting to use this disc, is there anything other than greasing up the bearings I need to do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teddy (punchie) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 3:04am
That should be about it, greasing the bearings. If they have gotten to the point where they are steel on steel, or worn lose.  I make packing from old twine and grease. Rapping it the right direction is needed,  Like putting on tiflon (sp)  tape, one way it works the other it just comes of. Don't over do it the with the twine shaft will not turn.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 5:07am
I bet it is over 50 years old. I am over 50 and I don't look that bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 12:25pm
Teddy, I will be giving it a look over Sunday, thank you for your advice!
Daniel
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 5:36pm
Hi Daniel.
I've got it's cousin here west of Mustang that has the back gang. Same hitch setup, too!
Where are you in Oklahoma?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 9:54pm
Hello Jim! That is great, I live south of Tulsa about 50 miles! Glad to see another okie here!
What is a "back gang" Jim?
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2012 at 10:02pm
it is another row of discs similar to what you have that attach to the rear that are angled opposite to what you have to make a more level seedbed
