Disc harrows parts
ScottClem2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScottClem2 Quote  Post ReplyReply Direct Link To This Post Topic: Disc harrows parts
    Posted: Yesterday at 7:41am
Hi all. Can anyone confirm the make and/or model of this disc? It might be the front section of a larger disc (not really certain). It has bearing housings with "WD28" stamped on them. The bearings are wooden. I need 4 bearing houses and bearings for it. Any help would be greatly appreciated.
Scott
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 49 minutes ago at 8:43pm
Unless you are just over flowing with luck, you can make them faster than the time you spend looking for them. Or convert them to something parts are a around for.
I have never made a wood bearing for a disc, so I could be wrong. But see what would be good hard wood, you can get your hands on. May have to glue pieces together to get a block and then find a whole saw as close as posable of the size you need. Then very careful use of a die grinder. That is if you really have your heart set on using this.
But that looks like really nice yard art.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 10 minutes ago at 11:22pm
I have used White Oak or Maple for bearings.  These woods work well for straw walker bearings and rotary hoe bearings.  I imagine they would work well for disc bearings also.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 52 minutes ago at 5:40am
Reaching back in my memory banks from my sawmill days I recall that we used wooden bearings on the augers in the sawdust bins; the bearing supplier told us that wooden bearings were still the best in certain low-speed applications where abrasive stuff was being handled.
I did a google search for "wood auger bearings" and got literally dozens of hits; there are many suppliers such as McMaster-Carr, Motion Industries, All States Ag Parts, etc. Also numerous custom makers.
Edited by Les Kerf - 3 hours 48 minutes ago at 5:44am
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 60 minutes ago at 7:32am
If you lack the necessary tools or skills to make wood bearings, contact a vocational teacher.  They often like little projects for their students.  I bet there are wood hobbyist in your area who would be happy to make them for you.
When I taught Vo-Ag, we made straw walker bearings for several farmer's combines.  Good project for the students. The students utilized their skills on drill press, mill, lathe and other tools.
