Diode instead of cutout on Allis B?
Fanmanj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fanmanj Quote  Post ReplyReply Direct Link To This Post Topic: Diode instead of cutout on Allis B?
    Posted: 10 May 2011 at 1:36pm
OK... my next question. I've checked out the generator on this Allis B. Changed the brushes, cleaned the commutator, and sure enough, she spins when 6V is applied. I installed it, fired up the tractor, and it still isnt charging! now there is this diode mounted to the generator, i'm guessing as some sort of modern repacement for the cutout? other than the diode, the electrical system looks in order. I can put the Charge/light switch anywhere, and the ammeter doesnt move... Help before I rip the 6V stuff off and install an alternator (which I dont wanna do).  I think I polarized the genny right. touched the armature terminal (the one with the diode) to the positive on the battery.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 2:12pm
Is your diode good ? check with meeter to be sure it is passing voltage in one direction or not open . If you ground the field you should have full output from gen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fanmanj Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 2:42pm
that's the strange thing... the field terminal has been grounded to the generator body with a short wire and eyelet (visible in pic), and the armature terminal is the one that goes through the diode.
cmsmoke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 3:05pm
  Aren't "B" models positive ground? If the feild terminal is grounded (full feilding the generator) it should be making full output. The red wire goes back to the ampeter then to the battery negative. The ampeter could be open as well. If it doesen't flow through, the machine won't charge. The diode only lets the current flow out of the gen.. If it wasn't there, the gen would spin just like when you powered it up.
  It has been a while for me to revisit a positive ground charging circut, but I will check the "C" manual tonight. Someone correct me, if I'm wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fanmanj Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 3:30pm
Yep it's set up as positive ground. I'll have to check the ammeter.
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 3:36pm
If you suspect the diode just jumper it to see if you get charging then.  The purpose of the diode is to prevent the discharging of the battery back through the genny when the engine is NOT running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cmsmoke Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 4:10pm
  Also depending on if your wiring has been reworked, the headlight switch origionally controls the rate of charge. See if it may have been bypassed and/or loose connections.
  This may help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 4:14pm
And if the light switch isn't grounded well, it won't ground the field even with good wiring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 6:40pm
The best test for that diode would be with a light bulb. A digital meter may not be able to "turn on" the diode. It should conduct power one way and not the other. The original generator should be a 3 brush style. The 3rd brush is used to set the max charge rate. You can remove the belt, disconnect the field terminal, and jump the diode with a wire. If the generator spins fast and slows down when you ground the field, you know the wiring and generator are good.
