diesel 170 intake question |
jmm ![]() Silver Level ![]() Joined: 06 Dec 2009 Points: 176 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Apr 2012 at 4:30pm |
hello,
on the intake of my 170's intake manifold is a port of some kind with what looks like a connection point for a wire. Also, I'm not sure if this should be the way it looks, but a line runs to a bulb in the engine return line. Can anyone give me an idea if (1) this is correct, and (2) what the purpose for this peice is?
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
It is the pre-heat system that Perkins used. I haven't had one that worked yet.....
ALLIS EXPRESS!
This year: |
and I suppose you've had a few, from the pictures i've seen. I did see a factory plugged hole on the dash. Is that what it is for? and... the fuel bypass job? my fuel return line broke, so I figured on bypassing it, and the fuel bulb ( I'm guessing that it has a small restriction to push fuel to the preheat). thanks for the reply
I think it is supposed to work off of the ignition switch, turn all the way clockwise, then release. Someone said you should hear a "poof" or see some smoke out of the muffler, but the one I think might work doesn't do that. It does seem to start easier if I click the switch a few times.
ALLIS EXPRESS!
This year: |
Hold the switch until you hear it ignite. It heats the fuel that is in it until it burns causing a small fire in manifold. MACK
