Did I blow my hydraulic pump?
1greenhornfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1greenhornfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Did I blow my hydraulic pump?
    Posted: 29 May 2011 at 9:29pm
I recently bought an old I-40 backhoe, after running about 3hrs,( I have  about 10hrs total experience), the hydraulics shut down. I didnt hear any breakage sounds, right after it happened I had hyd to the front loader but that went pretty fast too. Any advise on what to do next would be greatly appreciated. thanks
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2011 at 1:28am
have nuff oil in the resivor?
easygoin4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote easygoin4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:03am
I am a 2.5 yr owner of an I-40 Loader/Backhoe and have all the manuals for her- in Email format if you would like one send me an email.  I would like to see pictures of yours if possible.  My girl still works pretty good- just bushings/Pins little wore out along with a slow dropping boom and outriggers.  The main thing I wish is that the Loader had more KURL in it I find it hard to pick up a load with it.  I am new to this whole tractor thing but Love it.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 11:12am
Check the pump coupling.
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1greenhornfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 4:32pm
OK, had a friend look at it, didn't have tools to take off front grill, but he pointed out the chains were not lined up right at the pump. Hopefully not a broken shaft, I hope to get there tomorrow and open her up. please be easy fix, please be easy fix, please be easy fix...
pineyjd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pineyjd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 4:59am
If it's been sitting ?,I would change hyd filter,turn pump by hand if poss. to see if it binds.
the grill comes off easy 4 bolts & pump is not to bad to work on.
