deutz allis 5215?
allisd2112 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Topic: deutz allis 5215?
    Posted: 11 Sep 2016 at 11:42am
Any one have a 5215 with a 60" mower deck? Just wondering why the blades r Turing counter clockwise.so u can't mow very tall grass.belt is on right.what this a flaw in design? Any help would be great.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 12:41pm
I don't understand why you can't mow very tall grass?  As long as the discharge is on the side where the grass has already been cut, it should work fine.  The one on my AC 5020 worked fine.  I quit using it because the mower tilted where there was a slight incline so the grass didn't mow level, but otherwise it cut fine.
Not all mowers rotate the same way!
Maybe you put the blades on upside down?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 3:17pm
No grass comes out the discharge,all clippings build up in the rear of the deck? Blades are on right. Tall grass clogs the deck with no place for clippings to go.if the discharge was on the left side it would blow out discharge?
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 3:34pm
slow down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 3:35pm
if it clogs in the middle, the belt isn't on the right way on one pulley or more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 6:39pm
sounds like you need a belt routing diagram...
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 8:35pm
I got a diagram from dealer,the belt was on right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 8:45pm
Well, are you a first-time user of this particular machine and mower deck?? Because if you are, there is something WRONG with it. There is no design flaw. Those mower decks were the tops in the Industry at the time they were built. Sounds to me like its running backwards. Sure wish I could be right next to it and I'll bet within 3 minutes the problem would be solved.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2016 at 10:21pm
I had one. Nice little compact. Something is wrong, or it would mow.    IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 5:02pm
The big power pulley on the center of the deck runs counter clockwise.pto.. shaft runs clockwise.there is no way I have the belt on wrong.the big pulley should run clockwise,then the belt diagram would make the blades all turn right. I"ll try to post a pic of the belt diagram.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:05pm
You didn't answer my question.....did you just BUY this thing?????????????
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:47pm
Yes I did!it mows short grass nice.tall grass it just stops the blades.belt good and tight.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 7:58pm
Lefthand or righthand discharge?
Life is tough,but it's tougher when you're stupid. - John Wayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 8:08pm
Well, maybe your expectations of it's capacity are too high. It's a lawn mower, not a brush cutter. I'd guess anything over 4 inches is pretty tall for a mower like that and how low do you expect to cut it ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisd2112 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 8:57pm
Right hand discharge.my 16hp simplicity mows taller grass than thing.if I cut a hole on the left side it should work great.just a stupid way of doing it. I was just wondering if anybody else had a mower like this and the grass actually blows out the discharge! Unless I need special blades. I have ones with a curve upright bend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 9:04pm
That's why I was asking, my 5020 lefthand requires lefthanded blades. Thought maybe someone hooked you up with the wrong blades
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 10:13pm
    Sounds like the belts are old and worn and need to be replaced.
Dad always said," If you have one boy, you have a man. If you have two boys, you have two boys". "ALLIS EXPRESS"
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2016 at 11:12pm
I am just throwing things out here. Is it the correct deck for the 5215 ? Remember it is only 15 horse. And a lot bigger then a 16hp lawn mower. I could kill mine easy. You have to mow short grass with that rig. I used mine for a couple years, and sent it down the road. They are weak. Not enough motor for the size of tractor it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 9:01am
Is the mower deck nosed down?? Generally, those decks are supposed to be 1/8" to 1/4" higher in the front center. Nosed down won't work well at all.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 9:30am
at our shop we see many blades that are not right ...   rotation, lenght, bent, wore out, sharpened wrong ,upside down, loose , you name it    wish i could see it  we only sell and or sell a few hundred blades per year
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2016 at 9:33am
 dont know about that deck but some have mulching baffles under neath bolted on
