Deere Before Allis: |
Page 12> |
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2396 |
![]() ![]() ![]() ![]() ![]() Posted: 14 May 2025 at 6:49am |
3020 Deere. Really good condition but main hydraulic pump has taken to seeping. Works fine but is needing resealed. Owner purchased a brand new one as doesn't want to have problems later on as tractor is a working unit. Multi year loyal customer so I won't tell the family "No" to any work they need. Pays well too in cash at job completion:
Parking spot in the shop: ![]() Steer axle removed for clearance: ![]() Leaker: ![]() ![]() Damned pump is heavy so used transmission jack to remove it from the tractor: ![]() ![]() Owner ordered brand new rear tires and tubes and they will arrive at the shop this afternoon. Old dry rotted and cracked originals are full of calcium so I'll need to see if that gets replaced or not. I'll blast the rims clean and paint them up before remounting the new tires. This job will partially fund other projects going on around the "hood".
That's All Folks!
thendrix ![]() Orange Level ![]() ![]() Joined: 04 Feb 2013 Location: Fairmount GA Points: 5035 |
Whether you like green paint or not those 3000 and 4000 series deeres are some good looking tractors
Edited by thendrix - 14 May 2025 at 7:48am |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3828 |
every thing we work on here is green or red as they were the big dealers hear in the 60s 70s 80s
Green, blue, red, yellow, orange, really doesn't matter much to me as they all pay in the same shade of green which does matter.
![]() After moving fittings over with new sealing rings: ![]() Fasteners are in solvent tank degreasing so will slip it back together after lunch and wrap the job tomorrow morning. Greasy slimeball on the underside, (oh wait, that's me ![]() ![]() ![]() |
That's All Folks!
dkattau ![]() Silver Level ![]() Joined: 20 Mar 2011 Location: Nebraska Points: 288 |
If that new pump has a serial number plate, you’ll need to time it to the engine to prevent vibration in the hydraulic system. Outer dimple on the pump shaft goes in the 1:00 position when engine is at TDC.
Thank you, I've never heard that in the past. Both the old, and new pump have holes, or marks on the input shaft. I didn't know what they were for but was planning to align the new to the old before slipping the unit together. The engine has not been rotated but I will ensure the engine is on TDC now knowing. Thanks again.
That's All Folks!
Ky.Allis ![]() Orange Level ![]() ![]() Joined: 31 Jan 2010 Location: Kentucky Points: 1021 |
Is the new pump "Brand New" or a factory Re-Man? Just curious how proud JD is of it, $2K? Been helping a friend refurbishing a NH 2450 swather/haybine. The header is hyd. driven and brand-new (NH) hyd. motor was $2,800 with 6-month warranty and factory (NH) Re-Man was $2,100 with a 2-year warranty. Went the cheaper route.
I don't know myself but will ask. I know it came from Sloan's through my cousin I help out during harvest as he receives a discount.
That's All Folks!
Brand new pump supplied through Deere. I'm asked to not reveal price as a personal relationship is at play, but it is close to a reman unit in the aftermarket.
As prior poster mentioned, timing is important and I'm grateful this was brought up. The pump is shipped in the one o'clock position in the box so will align the crankshaft timing marks to correlate and slip it together tomorrow sometime. Owner is dropping the new tires and tubes tomorrow morning and doesn't want the calcium ballast in the new ones. I showed him the deterioration around the valve stem on one side and I may weld this closed and punch another through someplace else. Local tire vendor has beet juice and they'll install that for him.
Edited by Codger - 15 May 2025 at 6:41am |
That's All Folks!
I ordered a manual for this tractor series this morning. It will get use as they do plan to retain the tractor for some time. Only piece of equipment they have that is gasoline powered, but it is liked, and has a bit of history with it in their family.
Hopefully get this wrapped up and loader reinstalled over the weekend. More of their stuff needs to come over for both service, and repair.
That's All Folks!
Trinity45 ![]() Orange Level Access ![]() ![]() Joined: 17 Mar 2014 Location: Kentucky Points: 1846 |
We had a 3020 gas, worse tractor we ever had.
Like people, there are both good and bad. What specific problems did you have? Repetitive in nature, underperforming in tasks ask of it etc? This one I'm told has been a sweetheart and serves the purpose well. I have no experience myself so inquisitive in nature.
That's All Folks!
joe ![]() Bronze Level ![]() ![]() Joined: 30 Nov 2009 Location: SW Ontario Points: 154 |
Delete
Edited by joe - 17 May 2025 at 10:34am |
That's quite a price difference, and sometimes, with reman, you actually get a brand new part, but reman pricing and warranty. I hope it performs well for him, but I'd think long and hard, even at $700 more, and only 6 months warranty. Reman can often be rebuilding worn out components.
Pump slipped right in late last week, (timed correctly) and buttoned up as far as connections. I found the coupling hose for the fuel filler neck parted, (original) and the main suction hose between the oil cooler and pump inlet to be cracking and aged so am replacing via the local Deere dealer. Radiator hoses are being renewed also. Oil cooler was partially restricted so removed the same and going to pressure was it clean. No real way to get straight to it while in the tractor.
Also replacing the transmission oil and filters as several years aged in the tractor. Have two fresh five gallon pails of the Deere fluid specified by the dealership. Owner dropped off two brand new drive tires and three tubes and will have them filled with "beet juice". Pump installed: ![]() ![]() New cruising tires: ![]() Fuel filler hose on bottom of hood panel: ![]() Other end of hose on fuel tank: ![]() Oil cooler outlet, hydraulic pump inlet coupling hose: ![]() Oil cooler before removal: ![]() Oil cooler removed: ![]() ![]() New section of fuel filler hose. I'm awaiting the oil cooler discharge hose into the pump and should have Thursday. Strange size and I don't do "Fitz All" repairs if correct parts are available: ![]() Now off to Chicagoland to watch another 8th grade graduation ceremony.
That's All Folks!
Did you clean the transmission pump pickup screen too?
I have not at this time. Only drained the sump. I will have a book on the tractor tomorrow and that will guide me much better as I've never worked on one of these in the past. I did circulate the drain oil through my filter cart and plan to reutilize it as a flush prior to installing new oil. There really wasn't anything wrong with the former pump but a leaking front seal causing it to seep oil. Unless cost prohibitive to replace oil with a hydraulic pump change, I tend to do this operation as a precaution.
That's All Folks!
Any time you drain the hyd/trans oil on a Deere(10-60 series), you’ll want to check the trans pump pickup screen. It can save you a lot of trouble in the future. There’s a plug in front of the LH final drive. Takes a 1/2 inch drive ratchet.
Thanks kindly. Never seeing one of these in the past lead me to order a correct manual for it. I figured being a power shift unit there had to be screens and/or filters for service.
I should receive some coupling hose and the manual today and possibly get the tractor back operational by the weekend. Hopefully the loader frame goes back on as easily as it removed. I'll see this tractor at least yearly for maintenance routines into the future as I do many other pieces of equipment for the family. A service manual will be a benefit into the future. Thanks,
Edited by Codger - 29 May 2025 at 5:19am |
That's All Folks!
Since it’s a powershift, you might want to think about sliding a hardware magnet inside the pickup screen after you check it. That’ll pick up any future metal and keep it out of the planetaries and main hydraulic pump. I think I paid $10 for one about a month ago at the veterinarian.
Thanks kindly for that magnet idea. I actually install magnets most anyplace that will offer clearance if one is not present in gearboxes and such. Never a bad idea to pick up burnishings before they can circulate. Typically I'll glue a magnet to a drain plug if not that way already. I actually did just that on my White tractor last week when working with the finals, and transmission oils. McMaster has a plethora of types and sizes. Just received a text as I type this the parts order is in at the Deere dealer so very well may get this tractor back operational yet this week. Thanks kindly for your assistance. Been a real help with this project.
That's All Folks!
You’re welcome. Anytime.
Picked up the needed hose section, transmission filters, gasoline filter, air filter element(s), and two pails of the Hy-Gard transmission fluid. Owner has engine oil filters and I have bulk engine oil at the shop. Hopefully good to go in reassembly now. Still need to pick up a couple of hose clamps as the originals were not the worm drive types but rather the type where a machine screw locks them in place, (original).
Dealer had both the nylon screen, and stainless steel screens in stock should the original be compromised in any way. Not yet removed so no idea to original. Neither had magnets installed so no reason to believe original does.
That's All Folks!
Pretty fair progress in the few short hours worked. Oil bath air cleaner was a milkshake of water and almost softened creme cheese shown here:
![]() Transmission screen was incredibly clean and free from debris shown here: ![]() Same screen after cleaning: ![]() Filters were dated 1999 so no tellings how long since service but tractor has sat in conditioned space barn unused for a lot of years: ![]() I commented to the Deere dealer how much this looked the same as a Deere 350B dozer I'm vaguely familiar with. While he didn't know, the yellow interior paint is almost a dead giveaway to the multipurpose this casting played, and was built upon for different market segments. Will get to the engine oil filter tomorrow under this cover: ![]() Transmission drain oil was very clean with a light brown "tinge" to it. It is obvious the tractor has had an easy life mechanically and has been maintained well. I did speak with the original owner's brother whom I've known many years, (original owner deceased) and he tells me the tractor was so fuel hungry it always ran an auger and conveyor rather than plow, or tillage work. They kept it till the owner's passing as the only Deere tractor they purchased new. I'm told it was a good tractor but that used aftermarket wide front, (Speeco) was a purchase they wished they'd never made. By looking at it and the repairs, it obviously is not the best/strongest available. This has been an interesting learning experience for me. Have rebuilt engines and such for the brand but never have worked on one of their farm tractors per se'. Have a little experience with Deere dozers but that is all u/c work and tracks.
That's All Folks!
acken ![]() Bronze Level ![]() Joined: 02 Jan 2014 Location: Minnesota Points: 98 |
3020 gas power shift tractors were a bit starved for power. If I remember correctly the upshift from 6th gear was the worst jump.
I did drive this tractor just a bit before bringing it in for this work. The carburetor required a rebuild so was very sluggish on power. The main jet was almost totally restricted with this ethanol based crap we have to burn. That jump from 5th to 6th, 6th to 7th, and 7th to 8th was indeed awful steep. Once the rpm's came back up it had pretty good road manners as I was traveling at a pretty good clip by then. Thanks,
That's All Folks!
Finally located the second drain plug in the bottom of the transmission casting. With the screen out and a finger stuck into the opening hole there was still about an inch or so of fluid depth so something had to be missed. Found the second drain plug on the other side of the tractor restricted in oil/dirt mixture and untll cleaned, was hidden from view. Anyways, almost an additional gallon drainedhere. I ran a borescope into the openings and everything is very clean internally. A swipe with a finger yielded nothing unexpected so this tractor obviously has been cared for well.
I did glue a disc magnet to the lowest drain plug, and a strip magnet to the screen. These should suffice to capture any ferrous burnishings, (or such) and keep them from circulating. Also wiped clean the lowest points of anything that did not drain completely I could reach. Again, nothing really in the lowest point(s) accessible. I did not purchase that AGCO LT-70 tractor that was traded in last week. I seriously thought about it but it had to come with the 15' Wood batwing mower and I really don't have need for one of those in that size. After doing some online research, and physical measuring, the tractor was just a tad too large to store in my outbuilding, and I don't want to lose any more space in my shop for storage. One top of that I would have to lose the "White Honkey" which fits every need I ask, so final judgement was forego the acquisition. Hoping to finish this tractor over the weekend but jury is out yet. Son in law bumped a coon running across the road Thursday evening and busted the a/c condensor so have another to install later today. Thinking I can plastic weld the busted plastic brackets holding the bumper cover so while the a/c system evacuates I'll do this. Temperature is ramping back up this week and he drives almost 70 miles to work and returns daily so kinda valued in hot weather. |
That's All Folks!
Hydraulic pump job is complete and owner is advised of invoice total. Buttoned it up this afternoon and test drove the tractor around town for a spell. Runs/operates very well and upshift is very "crisp" as it should be. Immediate too at high engine speed.....
Started off this afternoon by prefilling the hydraulic pump with fresh oil to preclude dry start. Took almost 1/2 gallon by pouring a little in the inlet, allowing it to "burp" out and pour a little more. About 35 minutes later, it would take no more. Hose is shown full: ![]() Once the oil cooler was reinstalled over this hose and interconnections made, I filled the balance of the transmission/hydraulics with almost but not quite 12 gallons of "Hy-Gard" Deere specified oil. Then started the engine and cycled the hydraulics to purge any air entrainment. After satisfied with that progress, the front end went back under shown here with weight on wheels again: ![]() Happy with that progress, went ahead and built the sheet metal back up and into place. A little hammer and dolly work on one of the front closing panels, (Rt. side) diminished a crease pressed into it: ![]() ![]() Now fully satisfied with the progress and turnout, I took her around town for about an hour filling the tank and fully up, and downshifting at all engine speeds. City cops waved at me probably thinking, "Damn, he riding another tractor"!! ![]() And behind my house to look pretty for a spell. I'll stretch the new rear rubber onto it tomorrow most likely. Son in law has a couple of clean plastic barrels I'll capture the ballast with as I have a pump for the task: ![]() It's been a fun project, and I've enjoyed both the work, and the learning experience as have never done one of these. Profitable too which is what it's all about.
Edited by Codger - 01 Jun 2025 at 5:25pm |
That's All Folks!
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2454 |
I have an early LP version of that tractor,, but,, with a factory WFE...
I don't know the year of this one but assume it's late 60's to early 70's vintage. I'm told the engine has been fully rebuilt. It does start and run well. Everything seems to work except fuel gauge accuracy. Tractor is a typical farmer repaint as it comes off in sheets under pressure washer steam/water pressure to original improperly prepared original paint.
That aftermarket front end is not very good in my opinion. Might be fine in the field, but not very stable at road speed requiring constant correction. It has been damaged and repaired, (rather poorly) in it's defense. After conversation, I'm told a replacement will be sourced to install.
That's All Folks!
Page 12> |
