Deere 4020 schematic
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: Deere 4020 schematic
    Posted: 18 hours 35 minutes ago at 7:57pm
Anyone out there have an actual schematic for a 12v 4020 diesel? I’m doing an injection pump conversion and have lost power. The only thing working is the headlamps. Odd thing is that I have power to 2 of the three circuit breakers but I thought the dead one was the lights…..
pirlbeck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 50 minutes ago at 7:42am
If this is a side console tractor there is an inline fuse under the dash cowl on the LH side. To the left of the PTO lever. If that fuse is bad you will not have any power to the key switch circuit. Also, once again if it is a side console tractor there are 2 heavy wires that connect to the alternator battery terminal, that originally both wires were crimped into one terminal end, check to make sure these 2 wires are connected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 19 minutes ago at 11:13am
Thanks I’ll check both of those. I think I may have shorted the fuel cut circuit while I was testing it, so a fuse makes sense.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 18 minutes ago at 11:14am
Is this a side console tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 18 minutes ago at 12:14pm
Yes it is
Post Options Post Options   Thanks (0) Thanks(0)   Quote pirlbeck Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 55 minutes ago at 12:37pm
Yes it is
I figured that it must be as prior to 1969 and the introduction of the side console tractors they did not have a 12 volt solenoid shut off on the injection pump, although I have seen some added when a later engine was swapped in. Also, you mention an injection pump changeover which more then likely means you are replacing the CB injection pump with the JDB pump.
