Decals
70Standard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Topic: Decals
    Posted: 26 Nov 2011 at 3:44am
The last set of decals I used were the old water transfer type.  Now I see vinyl, cut vinyl, mylar, etc.  What is the preferred type?
Roof Palomino (SN 224), Chetech Pug UTV, Three Green Tractors and one Red Tractor.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 6:22am
We sell only the Vinyl die cut sets. If you take the time and money to restore and paint a tractor, why not use the best quility decals they make. David djstractorparts@yahoo.com
734-320-3470
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 6:41am
734-320-3470 begin_of_the_skype_highlighting            734-320-3470      end_of_the_skype_highlighting
Please explain why cut vinyl is better.  I have never used and would like to understand how it differs from the others.  Thanks.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 7:05am
The vinyl ones are like you used to get. Mylar ones are cheaper and will have a clear film between the letters. You can still use water to install them that way you can move them a little to line everything up. I bought a set from Maple-Hunter Decals for a 185 AC this year and they were nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 7:46am
What kind are the ones that are on an applicator backing paper, don't require water, and don't have the material between the letters?  Seems like I've heard claims that these look the cleanest (maybe not the most original) and are easy to apply - just line up, press on and remove backing paper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 7:48am
Vinyl have a front and back material that let you tape your decal in place so you can get it where you want it, IE (square, level, distance Left to Right) than you peal off the back and smooth down the letters to get out air bubbles ect, than you remove protective cover film. All you have our the letters with no clear film around them. When the paint fades on a tractor and you have used Mylar the paint doesn't fad under the clear and your decals look bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 7:49am
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 10:35am
David's pretty much nailed it.  We do carry both vinyl and mylar because our customers ask for them.
Mylar is a clear sticker with the ink on the sticky side.  1 big sticker for all letters.  as David said, the vinyl are each individually cut and layered to get the correct combination.  They cut them from the backing and "blank" or remove all waste vinyl.  Then a frisking paper is applied.  It's like a low-tack masking tape.  You pull the frisking paper and it lifts the decals from the backing.  Then lay it down on the surface.  Burnish down through the frisking paper, and then pull the fisking paper off, leaving the decals in place.
Vinyl will be thicker than factory, but it's the closest we have outside of the original liquid soluable (water slide from your model building days) decals.
I have some customers that went so far as to paint the markings on instead of any type of decal.  Done right, it's the closest to original, but requires a good painter and a thick checkbook.
JimD
Oh, and David is correct, when using the mylar with a cheap paint, the paint will fade faster away from the decal, but with a quality paint you will not have that problem, but a slightly more shiney surface where the decal is.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543
Post Options Post Options   Thanks (0) Thanks(0)   Quote 70Standard Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2011 at 4:25pm
David and JimD, thank you for the explanation.  Sounds like cut vinyl is the way to go.
