D-21 Prototype
Dean(IA) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Topic: D-21 Prototype
    Posted: 04 Jan 2021 at 1:50pm
Dean(IA)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 1:52pm
The D-21 prototype had D-series styling because of tractor company spies watching
the proving grounds.
Dean(IA)
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 2:05pm
Even with that tin it's a mean looking machine!  I wonder if all of the internals were the same seeing how that's a prototype.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 2:58pm
I like that look! Thanks for posting!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 4:04pm
for comparison
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 5:21pm
Cool picture Dean. But I like the final look even better. That thing was certainly a trend setter back in the day! Looked cool then and looks even cooler now.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2021 at 9:48pm
They should have somehow kept the snap on side hood arrangement.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 9:41am
Dean the picture that you posted is an artist's makeover of the production D21. The real prototype had a Waukesha engine with the exhaust and air cleaner in different location as seen in the video. A real version of the prototype build is in the planning stage !
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 4:26pm
 The real prototype had a Waukesha engine ..............why ?
 A real version of the prototype build is in the planning stage .......where ?
Calvin... can you elaborate a little more on the topic ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2021 at 6:22pm
Ive heard this too, over on Facebook- dont know the actual truth but would luv to know
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2021 at 7:38pm
Doug. It likely went like this. The race was on to have the first tractor over 100 hp on the market. Actually the JD 5010 was first but was a wheatland. D21 with the first row crop tractor over 100 hp (adjustable axle widths). The transmission and rear end were ready for production but the Harvey engine plant was still working on the engine. The 3400 (426) engine was the first direct injection engine designed for ag use. The 301 came later. The final design of the sheet metal and look was still being worked on. They needed to get the transmission and rear end tested NOW ! Down the road they go from Milwaukee and pick up 3 Waukesha 100 hp engines the same as the did for the first 96 B's and 27 WC's. Slap on some sheet metal that looks like the rest of the D series for now.
Look at the video and it's easy to see a much different engine. Some of this came from guys who used to work at the test farm.
Post Options Post Options   Thanks (1) Thanks(1)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 12:39am
glad they went with the look they did!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 6:37am
It's pretty clear to me the team that designed the "look" and operators platform for the D-21 weren't involved much with the mighty One-Ninety, which was also in the designing stages at that time. The rear mounted fuel tank, seat track and suspension and suspended clutch/brake pedals were shared, but not much else. No "console control" for sure. Almost hard to believe the two models were even related. Maybe distant cousins  ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 8:01am
Interestingly the casting supporting the clutch and brake pedals is the same for the OneNinety, 210, and 220.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 8:33am
Are there any pictures of the actual prototype .
nonetheless ,still dead.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 9:22am
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 12:21pm
This page was generated in 0.238 seconds.
