D21 hydraulic level check |
TerraTiger
Topic: D21 hydraulic level checkPosted: 08 May 2022 at 7:13am |
Where is the plug to check rear end/hydraulic fluid level. I found the fill area at the platform. Think I may also need to bleed suction line to pump, no power steering or 3pt functions and power divertor light is on. What is best way to bleed line short of taking it loose at the pump and letting oil drain there? Thanks for the help!
WLHD21
Posted: 08 May 2022 at 10:17am |
Dip stick under left side of seat , 3” plug in platform with spring clips Holding it down
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8729 |
Posted: 08 May 2022 at 11:10am |
On my 220 there's a cap plug on top of pump you can remove and squirt oil into pump to prime it. Likely slight air leak at inlet on bottom letting it loose prime.
TerraTiger
Posted: 08 May 2022 at 8:40pm |
Thanks for the help! Got it figured out now.
MACK
Posted: 08 May 2022 at 8:59pm |
Front pump seal needs replaced and tighten clamps on suction line. May also be time to clean screen on suction line in rear end. MACK
SteveM C/IL
Posted: 08 May 2022 at 9:53pm |
What did you do/find?
TerraTiger
Posted: 09 May 2022 at 6:54am |
Checked the level, none on dipstick. Need to pick up some fluid and go from there. Might be time to just change the fluid while I'm at it. How many gallons will I need?
SteveM C/IL
Posted: 09 May 2022 at 8:54am |
Good time to change and pull strainer out of front suction hole. My 220 took better part of 30gal drum.
