D21 hood expert needed
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Topic: D21 hood expert needed
    Posted: 09 Oct 2012 at 5:27pm
Need info on my series 1 hood. It has a door for small raditior neck,a factory cut hole for ex pipe diretly aboue center of manifold and a farmer cut hole for ex pipe at frontend of under hood muffler. These holes don't match hole in my series 2 hood. What do you think about this?? Maybe a straight pipe from factory? Muffler added later maybe. help help help
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 6:23pm
The farmer cut hole is probably the factory hole made bigger. I dont believe the hole directly above the manifold center to be factory. Might look like a nice cut but not factory. I have one NOS series one hood. I can send pics of if needed. Hth great lookin tractor by the way.
dbounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 7:33pm
I agree that hole above middle of manifold was probably cut to attach straight pipe and do away with original under hood muffler. Series 11 would be different. If someone has an extra series 11 hood they would part with I would be interested !!!  Doyle
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:21pm
Austins in Bulter had one a while back. Maybe try them.
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:30pm
maybe that explains the series II decal, maybe it's a series II hood that someone cut the hole for the series I exhaust?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:40pm
Door to get to radatior looks too good to be added.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:42pm
got me then Henry.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2012 at 9:46pm
the series 1s had the door  for the rad cap
