D21 front wheels ,8 hole to 6 |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8356 |
![]() ![]() ![]() ![]() ![]() Posted: 15 Jul 2012 at 5:59am |
I thought this was a topic while back but cant find anything on it, im wanting to put 6 hole wheels on my 21 , are an XT bearings and hubs the same? ? Whats a good swap? ?
DarrylinWA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Amarillo Texas Points: 1900 |
I know the 6 lug is original for the series 1 D 21 tractor. I think you can use the XT, but I am not sure.
Happy hunting! Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
dustinmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
Do you know when they changed from 6-8 (serial #) as I have a brocure and some other lit that shows the series 1s with both and I have serial # 1300 and it looks to has the 8 hole and one orig rim even with the galv rim and the white center, thanks guys, Dustin
Luke R. ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: SE Iowa Points: 1262 |
I dont think you can use the XT set up. Bearings are different i think. Otherwise the six bolt hubs wouldnt be so hard to find. But i could be wrong.
dbounds ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Albany, Mo. Points: 232 |
our serial #1251 63' had the 8 bolt and our 64' has 8 bolt. I think it must have been an option and most took the 8 bolt. If the 6 bolt uses the same spindle (never seen one up close) then 190 stuff won't fit. Doyle
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8635 |
Lot of times same hubs use different brg race dia to fit diff spindles.
