D-21 front hubs
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: D-21 front hubs
    Posted: 11 Jan 2012 at 8:11pm
is it possible to mount a smaller 6 bolt hub to front spindles on a 21? would like to mount a smaller lighter front wheel in place of heavier 8 bolt hub and wheel
Cowboy UP
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 8:13pm
i had a d21  series 1 that had either 5 or 6 bolt hubs, not sure which but the earlyones didint have 8 holes
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2012 at 9:05pm
 The first D21's had a six bolt hub.
                       IG
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 12:28am
Yes it will inner change. from 6 to 8 lug. Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2012 at 7:05am
As long as the bearings are the same size , it,ll work
