D-19 serial # location ?
rodnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Topic: D-19 serial # location ?
    Posted: 23 Oct 2016 at 6:54pm
I know what Terry Dean's book gives for the location but I can't locate it. I'm looking on top of the rear end housing below the back of the seat frame. removed some paint but have not seen a number. Do you have to remove the seat frame to locate it ? Where am I going wrong?
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 6:59pm
Hi Rod.
It's right next to the very back edge in the center. Might have a hydraulic line over it.
It should be directly behind the seat base on top.
Edited by Jim Hancock - 23 Oct 2016 at 7:02pm
How blessed we are by HIS GRACE!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 7:09pm
JIM, is under the hitch caution decal? Or am I to far back?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 7:13pm
If there is a decal in the back center top next to the back edge, it could be there under it.
It'll start D19 xxxxxx
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 7:16pm
THANKS, I'll look there tomorrow morning.
orange-is-power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange-is-power Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 11:20am
Seems like it may over to the left of center. Been awhile since we had one, but I remember it took me a while to find it the first time. If it original, there shouldn't be a decal or line covering it.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 9:04pm
Hello Rod     Try looking on left front of torque tube behind engine.   Allen
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2016 at 7:25pm
I found it this afternoon. The D-19 and the first two numbers were under the caution decal for the proper use of hitching to the tractor. This area is below the rear seat pan on top of the rear end housing. It was were the book said it was to be found, but under the decal.D-19 6893. 1962 model narrow front gasser. Thanks for the help
