D19 rear wheel hubs
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Topic: D19 rear wheel hubs
    Posted: 15 Oct 2016 at 7:59pm
Ok guys what's the trick to get the centre wedge hub out to move it on the axle. One of my books shows a special pusher bolt, are they still available from agco or does anyone have a set they would part with?
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2016 at 8:06pm
Agco has them but be prepared to pay!!
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 6:54am
Put a piece of metal in the gap between the hub and the wedge, Then use a bolt that fits in the threads of the wedge, the bolt will bottom on the metal piece and push the wedge out of the hub.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 10:13am
it will take some heat
phil
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 10:23am
This old thread may help
http://www.allischalmers.com/forum/forum_posts.asp?TID=70295&title=190-hub-removal-bolts
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 11:36am
The pusher bolts work great and are worth the investment is moving wheels is something that you are going to do often. But if it is a one time deal I would try some of the other suggestions posted on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Oct 2016 at 12:37pm
Ok thanks guys would like to narrow it down, it has been set out to the widest position and it's a pain to load on my 83" trailer!
