D-19 Propane overhaul kit
Sadowsky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sadowsky Quote  Post ReplyReply Direct Link To This Post Topic: D-19 Propane overhaul kit
    Posted: 21 Feb 2013 at 8:57am
Years back I bought an complete overhaul kit for a D-19 262 propane engine. This kit is identical to the gas engine kit except the wrist pin sits lower in the piston to push it up higher and get I believe 40 psi higher compression. I've been told this kit is no longer available. Any chance anyone would be interested in it? I remember this one costing around $2,000 back in '99 or 2000.
A-C Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote A-C Guy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2013 at 10:07pm
Do you still have the D19 LP overhaul kit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sadowsky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 6:36am
Yes I still have the kit.
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 7:18am
Can you post what the piston part number is ? Thank You.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 9:07am
Compression ratio should be 9.35 to 1 for LPG versus 8.0 to 1 on a gasser.
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 4:23pm
I KNOW A GUY THAT WANTS ONE Smile
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sadowsky Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 7:32pm
Tell him I'll be glad to hook him up!
Fields: on the piston part #, I will get the kit tomorrow and see if I can find that.  Thanks everybody,
Justin
Edited by Sadowsky - 18 Mar 2013 at 7:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2013 at 7:50pm
MR.Sadowsky .. i sent you a pm
