D19 Power steering
allisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisnut Quote  Post ReplyReply Direct Link To This Post Topic: D19 Power steering
    Posted: 16 Apr 2012 at 6:34am
I just replaced the power steering lines and some of the seals in the front end and now when I start the tractor the steering wheel spins all the way to the right without anyone touching it and I can't turn it to the left with the tractor runing any ideas would be great
THanks Phil
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 6:52am
          You might have air in the lines and everywhere after having changed all the lines. If you move the steering wheel all the way to the right and then left you might get the air out after a while.
                            John Carlson
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 7:51am
Steering valve not propperly adjusted. Take the valve back apart and adjust it according to manual.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisnut Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 8:02am
I did not have the valve apart just the back cover to replace the seal were the steering saft comes out Thanks Phil
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 9:14am
you might have two lines switched.
