D19 D oil and hydraulic fluid
Mottwelding View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mottwelding Quote  Post ReplyReply Direct Link To This Post Topic: D19 D oil and hydraulic fluid
    Posted: 20 May 2016 at 8:32pm
So my operators manual is not here yet and the service manual does not tell you this. I found a post for napa filters 1515 but it was for a gas tractor will that work? looks the same as my baldwin filter that came off.
Also how much oil does one of these tractors take?
Also how much hydraulic transmission fluid? and where do i fill it? is there different spots to fill??
thanks so much!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mottwelding Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 10:57pm
I have the final drive drained, and the pto drained, I changed the diffs with a little over 2 gallons in each of 80/90, i will be doing another service on these in a couple weeks as all the fluids were pretty nasty.
This page was generated in 0.039 seconds.
