D19 3pt lift capacity
Jake79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake79 Quote  Post ReplyReply Direct Link To This Post Topic: D19 3pt lift capacity
    Posted: 12 Sep 2019 at 8:09pm
I have looked through manual on lift capacity for tractor but had no luck. If anyone has any input I appreciate it.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 9:30am
Looked on tractordata.com, didn't find an answer to your question. Thought we had a similar topic not too long ago?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 9:44am
between D17 and 190 if you can find those stats
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 9:48am
There were no published lift specs. Let's reverse the question. What are you trying to do??  A large round bale of hay shouldn't be a problem.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 10:18am
^ that's surprising
AC had the spec when designing the system; odd that they did not publish it.
Were other tractor companies the same?
Our D17 had capacity enough to lift the whole (wide) front end.
I'm sure the D19 would be similar, but it would be difficult to ascertain any valid number based on that capability because of the complicated geometry.
A guy could mount a 3pt carrier and keep adding weights until it would not lift anymore.
Edited by Gatz in NE - 13 Sep 2019 at 10:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake79 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 10:23am
Thanks for answering. Yes I cannot find anything either anyplace. #1400 disc mower is the thing I'm concerned about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 10:26am
If the hydraulic system is in good condition, it shouldn't be a problem. A 4 x 16's fully mounted 80 series plow weighed 1385 lbs.
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 11:48am
I can't say what a D19 will lift but, the following is what I found on what the different hitch capacity's are.
At 24" (61.0 cm) back from implement’s lower 3-point hitch pins.
Cat 0, 700 lbs (317.5 kg)
Cat I, 2000 lbs (907.2 kg)
Cat II, 3600 lbs (1632.9 kg)
Cat III, 13600 lbs (6168.9 kg)
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 12:02pm
My D17 will lift my Allis 4-16 fully mounted 3 point plow. If it is the same weight as your disc mower I wouldn’t think it would have any problem. I think I would want wheel weights or fluid in the left tire though.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 1:07pm
The 3600# max weight sounds about right, we blew the seals at 3850# repetitive lifting on a 185.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2019 at 2:33pm
My 190 would not lift a pallet with 4000 lbs of steel on it it did however lift the front end off the ground. With my 350 lb brother on the front end I was able to move the pallet 30 ft with it just barely touching the ground.
