D17seriesIV power director
d17series4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17series4 Quote  Post ReplyReply Direct Link To This Post Topic: D17seriesIV power director
    Posted: 26 Jun 2015 at 3:50pm
I have a series4 d17 that will sometimes pop out of high range if I hit a big bump or crack in the road it will pop out. Is there any adjustment or is the power director just wearing out. It works fine otherwise. Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 4:15pm
Your issue is wear on the 3 rollers and 3 ramps on the preload plate in the high side of your power director.   You can't really adjust for that, they need to be replaced.   If you adjust shims to make it tighter on the high side, it might pop out worse I'm guessing.  Here's are some pics of where wear occurs on the pre-load plate.  I had to replace this high side preload plate and all the rollers on my Series IV and after Don(MO) did the work for me it is GREAT.   Mike
Edited by Skyhighballoon(MO) - 26 Jun 2015 at 5:12pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 4:33pm
Well, start by removing the stop bolt that the hand lever rests against when it's in high range. Then, see what you have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17series4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 4:36pm
My stop bolt has sever ral washers behind it. How many are supposed to be there?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 5:16pm
However many or few to allow FULL engagement of the lever all the way forward in the high side.  Pull the bolt out, put it in high then add bolt & adjust washers so it doesn't restrict it from going all the way in the high side.   Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17series4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 7:56pm
Thanks everyone
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 8:31pm
And make sure the lock bolt on the bottom of the arm is tight. Loosen the lock nut and tighten the bolt.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2015 at 9:37pm
I see my finger prints all over this. lol
