D-17
Darrell/MD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell/MD Quote  Post ReplyReply Direct Link To This Post Topic: D-17
    Posted: 27 Jan 2012 at 9:40pm
I'm have a D17 diesel SER IV. I need engine block, either
complete engine or short block. any idea where to get either
one in Maryland. A complete engine will be less work.
Darrell
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 5:57am
I just did a complete overhaul on mine. I would recommend you build one instead of buying one that runs. The sleeves have problems with dropping in the block and then headgaskets don't hold long term. It gets expensive in a hurry to repair sunken sleeves.
RPSallispullinmd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RPSallispullinmd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2012 at 6:59am
I have 2 262 gas engines that you can use the blocks to make your diesel engine can call me at 410-924-1933.I live in Easton.Thanks
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2012 at 12:14am
Sunken sleeves are not that hard to fix.
You can have the block machined and an insert installed to bring them up to the proper level or you can use Belzona Super Metal (1111) to act as a shim.  Have done this on some industrial engines with no problems.
This page was generated in 0.119 seconds.
