D17 wide front
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: D17 wide front
    Posted: 08 Oct 2017 at 8:43am
Found a series 3 D17 with this front end. The pivot under the bell housing is welded and looks home made. What should it look like?
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2017 at 8:49am
Looks like front for older D 17.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2017 at 11:19am
Correct for Series 3,but for a diesel.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2017 at 8:40am
Sorry, you are incorrect.  A diesel wishbone will not fit under a gas engine (longer than a gasser).  Very late series II was the change to the bigger wishbone.
This is my neighbor`s all original Series III diesel...
