D17 valve adjustment |
| Author | ||
waw1962
Topic: D17 valve adjustmentPosted: 15 Jul 2024 at 10:38am |
The shop manual for the D17 series IV states to set valves 1,2,4, and 6 when TDC, then 3,5,7 and 8 at 90 degrees rotation of the crankshaft. Others have stated to set them in firing order, 1,2,4 and 3. Which is correct? Thanks.
| Sponsored Links | ||
Posted: 15 Jul 2024 at 11:23am |
Either way works. Set ALL at .015" COLD which that book will not tell you.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8792 |
Posted: 16 Jul 2024 at 7:10pm |
90 degrees doesn't sound right....you better just do each cyl on TDC
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4025 |
Posted: 16 Jul 2024 at 11:26pm |
one full rotation of the crankshaft. two full turns on the crank = one full turn of the cam
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3101 |
Posted: 17 Jul 2024 at 6:49am |
I haven't done many, but when I set them I just turn it over a few times watching and catch each valve when it's all the way closed. I don't worry about TDC and the firing order. These are pretty easy to do that way becasue duration is so short. They are fully closed most of the time.
nella(Pa)
Joined: 11 Sep 2009 Location: Allentown, Pa. Points: 3140 |
Posted: 17 Jul 2024 at 7:01am |
Take out spark plugs! TDC on compression stroke.
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2259 |
Posted: 17 Jul 2024 at 11:08pm |
Yep
Intake valve closes you are good to check valve clearance on both... |
Jim.ME
Posted: 18 Jul 2024 at 9:15am |
4 cylinder overhead valve with the rocker cover off, it is pretty simple to watch the companion cylinder for the valves to be "on the rock" (exhaust valve closing and intake opening), to be in the correct place to set the valves on its cylinder with both valves closed, ready to fire. 1 and 4 are companions and 2 and 3 are companions.
Edited by Jim.ME - 18 Jul 2024 at 9:16am |
NEVER green
Posted: 18 Jul 2024 at 9:27am |
Racer's set them the EOIC method, do each cylinder one at a time, as soon as the exhaust opens set the intake, as soon as the intake closes set the exhaust. I have used it for years.
