D17 Start tractor up hydraulics go up |
lumaro
Joined: 29 Oct 2013 Location: Poynette Wi Points: 7 |
Topic: D17 Start tractor up hydraulics go upPosted: 07 Aug 2017 at 3:27am |
Hi i have a 1964 D17 Allis The problem is when I start the tractor up the hyd start going up it will keep going full psi, it blow one on the cylinders for the bucket it will not come down. l I have back the down speed control all the way off also the traction and the hyd control are not working right do I have a pump prob.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54756 |
Posted: 07 Aug 2017 at 4:43am |
Check the linkages, then the pump...
Posted: 07 Aug 2017 at 7:21am |
Sounds like a one-way loader with a trip bucket???????????? Be nice to have good information. I'd be thinking traction booster linkage underneath the belly is bent or disconnected causing the pump (Pre-series 4) to pump all the time.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7580 |
Posted: 07 Aug 2017 at 9:42am |
Yep, need to know if it is a series IV or not. I suspect it is a linkage issue.
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 07 Aug 2017 at 3:41pm |
I had my WD hydraulic lift go up and not want to come back down immediately upon start up and it turned out to be a broken spring stuck in a spool inside the pump. Similar pump to the D17 Series I, II and III. SeriesIV is different.
Edited by Lonn - 07 Aug 2017 at 3:42pm |
Wink I am a Russian Bot |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34440 |
Posted: 07 Aug 2017 at 7:14pm |
Lumaro talks about loader bucket cylinder...
...so I think he has separate control valve for the loader and running the D17's pump through it... and the pump is pumping all the time so... I think he has either control valve unloading valve issue or the pump linkage is disconnected... or the traction booster linkage is bent, but the lift/lower control in lower position would relief the traction booster too so back to the lift/lower not functioning... just my guess. |
