D17 snap coupler and WD45
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Topic: D17 snap coupler and WD45
    Posted: 01 Jun 2011 at 10:14pm
Are snap coupler implements interchangeable between the 45 and 17, or is the length between the bell and lift arms different?
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2011 at 11:26pm
I know of know differences, the Snap Coupler system was designed by Allis to be a common interchangable system.
Still in use:
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2011 at 12:23pm
The only differences I have ever noticed between the two are that some of the newer machinery for the d17 was built heavier than that for the 45's.But as far as I know they will all interchange.
Okiejohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Okiejohn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2011 at 10:05am
I've used my 3-bottom plow, angle blade, and 8' SC implements that I got with my dad's WD with my D17 with no problems, other than adjusting the plow, which has noothi9ng ot do with it fitting on the tractor.
Be sure you are right, then go ahead.--Davy Crockett
