D17 SIV 3 POINT DRAWBAR |
Hardway(WA) ![]() Bronze Level ![]() ![]() Joined: 14 Sep 2009 Location: Spokane, WA Points: 9 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Jun 2011 at 8:18pm |
I am converting my snap coupler to a 3 point set up. I am all finished except the drawbar. I have the 3 point drawbar, but I cannot find in my parts or shop manual, a picture of how it is supposed to be attached. Does anyone have an picture or drawing of how the drawbar attaches underneath the tractor and could share here? Thanks Chris.
Claus ![]() Orange Level ![]() ![]() Joined: 09 Dec 2009 Location: Hebron In Points: 1154 |
I think you need a bracket where the pedals mount.
Sorry for the crappy photos, not the easiest place to take pics.
Let me try this again.
Thanks for the photos Claus. I do not have this bracket, anyone know if they are available, say at Cook tractor or otherwise?
Here are some pics of what I have.
My photos are of my 170, I would think the D17 is the same. Is there anything wrong with leaving your Snap-Coupler drawbar the way it is?
My only issue is the 3 point drawbar is a little longer.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21724 |
I doubt it.....the length of that SnapCoupler drawbar is accurate for any 540 PTO powered equipment and the three point hitch drawbar would/should be the same. This way, if you use the 3pt hitch you may have to slide the snapcoupler drawbar out and off the tractor so it doesn't interfere with whatever it is you have on the 3pt hitch.
JoeO(CMO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Cent Missouri Points: 2694 |
Like DrAllis says, the length of the drawbar is correct, ASAE Standard, height is also correct, both in relation to the end of the PTO shaft. There is nothing wrong with running it that way. With a 3-point drawbar you can further and deeper into a mudhole. The Snap Coupler will help stop you so you won't get into too much trouble.
Ray ![]() Orange Level ![]() Joined: 21 Sep 2009 Points: 1979 |
Hi: I have the original bracket that bolts under the tractor that bolts on with 6 bolts. The brake rod goes thru it and the draw bar has a hole in the back. Let me know if intrested. 785-353-2392 Thanks
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1277 |
The 3 point version drawbar is longer by look of the eye. It mounts further ahead on the tractor though. So in the end the drawbar hole is in the same place no matter which style you use.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
and....you will have to find the correct drawbar, which may be hard to find. The 3pt drawbar has a big bend in it. Did you get the steering fixed??
ALLIS EXPRESS!
This year: |
