D17 Series IV Clutch Replacement.
stroketech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stroketech Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Clutch Replacement.
    Posted: 09 May 2017 at 2:39pm
Hi guys, due to the search not working I'll just ask. The pilot bearing went out on my 65 D17 series IV. Any special tricks to splitting a Series IV or just straight forward? Also what's is everyone's opinion on a replacement clutch brand/kit?
Thanks.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 9:04pm
Very straight forward.  Replace the throwout bearing at the same time.  I also like to replace the seal on the input shaft of the torque tube while I am in there.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 8:48am
Straight splitting, I was told the series 4 has a different clutch than earlier 17's. someone else post back on this, I just heard this and am not 100% sure.
old farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote old farmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 9:19am
They have a clutch that has two surfaces to it. One where pressure plate bolts to and then one where clutch surface is. Both surfaces MUST have the same amount removed for the clutch work correctly.
This page was generated in 0.052 seconds.
