D17 Series IV 5 lug to 6 lug
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV 5 lug to 6 lug
    Posted: 06 Jul 2021 at 8:04am
The tractor is a D17 Series IV SN 78155.
I currently have a 5 lug setup.  I have bent a 2nd wheel moving hay bales through the field.  Maybe I am going too fast.  I actually only bend the aftermarket wheels.  The right wheel is still an allis brand wheel.  I noticed when I bought the wheel it said not recommended for front end loader.
I was thinking of stepping up to a 6 lug.  Do you know if I can use the same spindle and just swap the hubs and wheels?
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 8:36am
The outer bearings are the same 5-bolt vs 6 bolt. The inner bearings for 5 bolt are 1.5" ID and 3" OD on the race. The 6 bolt inner bearings are 1.625" ID and 3" OD. You should be able to use the 5-bolt hub bearings in the 6 bolt hub. Never done it yet, but I will be swapping to 6-bolt hubs on a late D15 series 2 in a couple weeks.
www.awtractor.com
A&W TRACTOR 920-598-1287
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 8:42am
I did one just changed the inner brg cup and race my brg suppler got me the parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 2:34pm
Gee: you bent a wheel that stated was not for loader use when using a loader. Go figure. Wacko
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2021 at 2:06pm
Robert I got my bearings for my D17 through Agco.They were surprisingly reasonable actually.Here are the numbers for DFW(narrow front) and RSFA(wide front).The inner bearing cone and cup are different from wide front to narrow front.The outer cone and cup are the same for both front end types.No spindle change needed to do this.
2
70222214
2CONE, BEARING, INNER (5 BOLT HUB)
70209899
2CONE, BEARING, INNER (6 BOLT HUB R.S.F.A.)
70047751
2CONE, BEARING, INNER (6 BOLT HUB D.F.W.)
3
70209987
2CUP, BEARING, INNER (5 BOLT HUB)
70235089
2CUP, BEARING, INNER (6 BOLT HUB)
Edited by ac45dave - 07 Jul 2021 at 2:08pm
