d-17 series four govener problem
dirtwork View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtwork Quote  Post ReplyReply Direct Link To This Post Topic: d-17 series four govener problem
    Posted: 12 Sep 2011 at 10:40pm
i think something happened to my govener it will idle fine but when you give it a little throttle the rpm keep going up untill you push the throttle back to a idle.How hard is it to get to the govener weights?
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2011 at 10:44pm
Governor weight broke off.  Probably have pieces down in oil pan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dirtwork Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2011 at 10:49pm
how hard is it to replace weights?
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 8:36am
Pull the distributer houseing out of the tractor, you must find the two steel wear inserts from each of the gov weights as it will ruin the cam and/or crank gears if it goes thru them, some stuff may be in the oil pan.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2011 at 9:02am
Check your timing gears really really close for bent or broken teeth. Will cause a knock if bent tooth and if you replace one gear you should replace all or an unseen bent tooth will just take out teeth on new gear. Don't ask how I know. Hopefully you don't have gear damage.
Wink
I am a Russian Bot
