D17 series 3 power director |
Dave Wisc. ![]() Orange Level ![]() Joined: 12 Jun 2015 Location: Wisc. Points: 216 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Aug 2019 at 5:27pm |
I know this has been on here before but my power director lever pops out of high range today when working it hard to load manure. How do you fix it???
den/southern illinoi ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2061 |
A few possibilities.
Make sure that the set bolt that holds the lever to the shaft is tight so that the shaft makes the full motion. There is a stop bolt at the front end of the travel...may need to back it off a little so the power director will lock in. Shims can be moved inside but that's all I'm going to say about the shims as I have not moved them in a hi-lo type unit. Have done the WD/WD 45 types but they are different. These are some of the ideas that I remember reading on here. I would think that those with more knowledge will check in with more. Den |
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts. |
Overcenter plates will need replaced and rollers checked. MACK
Ok The stop bolt is not there . I moved the plate forward ad it was slotted it seemed to help as it didn’t do it again.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21471 |
Most likely to jump out when oil is cold and engine is wide open throttle.
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2919 |
Power director stop bolt on my D 15 is also gone . It does seem to work fine . Thanks
